car wont start no fuel! HELP
Old Oct 30, 2006 | 05:19 PM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
I took my car out of storage after 2 years...........It wouldn't start and I figured out that it was the fuel pump. I replaced the fuel pump in may of 2006. After replacing the fuel pump it started right up and ran fine! I took the front end of my car off in august because I had gotten in an accident 2 years ago and I finally had time to fix it. I replaced everything on the front end and put everything back together. I went to start it and it start but ran really hard. I tried putting it into drive and it would stall right out. I checked for spark and I didn't have much so I replaced the ignition control module. I then got plenty of spark but she still wouldn't start. I then figured I didn't get any fuel. I check to see if the pump might be bad but just as I thought it was just fine. I check the filter and that is fine. I took the inlet and outlet fuel lines off to see if I was getting fuel and I was. I then check for fuel pressure and it was 40 psi with the engine off and the key turned on. I replaced the fuel pressure regulator. I put everything back together and it still wont start. I am very lost right now I have no idea where to turn to figure out what is wrong. I couldn't image all of my injectors are bad. I have spark at the distributor and at the plug. The plugs are brand new. I have no idea what could be wrong. Please help ASAP. I live in michigan and it is going to snow soon.
Old Oct 30, 2006 | 05:40 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Have any idea if your getting injector pulse? If your not.. maybe one of the ground got messed when you were reassembling/ dissasembling the front end
/shrug
hope this helps
Old Oct 30, 2006 | 06:42 PM
Engine: 5.7 Liter
I used a noid light to check the firing of the ECM computer and injectors and it all works right!
Old Oct 30, 2006 | 07:09 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just an idea, but you could have bad gas after sitting for 2 years.
Old Oct 30, 2006 | 07:39 PM
Engine: 5.7 Liter
I put new gas in it when it was running rough!!!!!!!! Could all of the injectors be bad because I was trying to put 2 year old gas threw there?
Old Oct 30, 2006 | 08:02 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well 2 year old gas sitting on the bottom of the tank can't be good, have you checked the filter?
Old Oct 30, 2006 | 09:30 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
/agree check the filter
and if its ok id try to put some sort of gas treatment in it anyhow..
Old Oct 30, 2006 | 11:05 PM
Engine: 5.7 Liter
I have no problem getting the gas to the fuel rails but after that I am not getting anything......I replaced the filter already. I don't smell any gas even after cranking it for a while. I replaced the fuel pressure regulator and that didn't work. The only thing I can think of now is to replace the fuel injectors please let me know if I can do anything before this.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
