My Car Stalled...
Old Oct 30, 2006 | 08:29 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
My Car Stalled...
...And I have no idea why. I put it into reverse to back into my garage and it just shut off, no sputtering or strange noises. Nothing. I turned it back on, and backed it into the garage. No problems.
The only things wrong with it mechanically are coolant leaking from one of the head gaskets, and a slow tranny leak. Other than that, she's been running like a champ. The ignition system is all fairly new. And I maintain the car on a regular basis.
So the question is, would the computer have something to do with it?
Thanks a lot in advance.
Old Oct 30, 2006 | 09:29 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
TBh with you, It could be a one time thing, my 350 is a little bit picky in cold weather, itll stall the first start(high idlethen slowly go's down and caput) then be fine all day
Old Nov 1, 2006 | 05:00 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I think you're right. I've been driving it the past few days, and no problems.
I was just concerned that there may be trouble with the computer or something. Well, if anyone else has any ideas let me know. Thanks.
Old Nov 1, 2006 | 05:33 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Mine does that occasionally. Just a random stall backing up when its cold. I think it may have to do with a sticky IAC. If the computer can't adjust the mixture fast enough the car stalls.
Old Nov 1, 2006 | 05:48 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I live in Miami. Cold weather isn't an issue.
I also serviced my IAC in the past year or so.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
