Powermaster Mini Starter Problum
Old Nov 1, 2006 | 07:44 PM
mytagta's Avatar
I have installed a Powermaster 9600 153/168 Tooth mini starter on my 89 GTA 5.7 . I am expirencing problums. When I turn the key the starter gear is engaging but hits the fly wheel on the way out. The only way i have been able to over come this problum is but going underneath the car and turning the pinion gear by hand before trying to start the car. I am getting really sick of this issue and have called powermaster to try and solve but they claim it to be an electrical issue. I checked and its all fine. Can anybody please tell me what i can do to solve this?
Sorry if this is a repost. I have searched and i have not come to any answer to fix this issue.
Last edited by five7kid; Feb 6, 2007 at 01:37 PM. Reason: Forgot to Add information
Old Feb 6, 2007 | 11:54 AM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Mytagta,
Did you ever figure out whats going on with your starter? For me I bought a hitachi starter because I thought they where good and the guy at the shop i went to was raving about the long lasting motor they use. I went and installed it i engaged the starter and it would not retract from the flywheel. I took it back to them and now I have that same starter (powermaster 9600).
Im going to be installing it today so I'll let you know how it works out.
Good luck man
Rabi C.
Old Feb 6, 2007 | 12:00 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Originally Posted by onfire
Mytagta,
Good luck man
Rabi C.
If it would engage and crank, but not retract, to me it sounds like you didnt have it shimmed correctly, as i have had this problem with all aftermarket chevy starters.
Old Feb 6, 2007 | 12:04 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
ever try to shim it?
Old Feb 6, 2007 | 01:03 PM
Gramps's Avatar
Car: 87 Camaro IROC
you need shims man, not all starters are alike. i bought a good acdelco starter and installed it w/ no issues, and the next one i bought i had to shim it. its really stupid but it has to be done.
PS: why is the screen so wide?...i have to scroll over just to reply to the thread.
Old Feb 6, 2007 | 01:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Something with the sig. Doesn't do it now that the sig is removed.
Anyway, back to the problem: Are you using a remote starter solenoid?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
