knock sensor wire or coolant temp?
Old Nov 2, 2006 | 09:59 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
I have a 89 350, which wire goes to coolent sensor and which one for knock sensor? they are both one pin, one is yellow with a white plastic connector and the other is purple or black with a black connector? thanks for any help.
Old Nov 2, 2006 | 05:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
One is a knock sensor like you said - the other is the FAN SWITCH - not the coolant temp sensor. Turn the key on (no run, just on), and ground each one at a time - the one that is for the FAN SWITCH will make the electric fan start running when it's grounded and key is on.
The fan switch is in the head, the knock sensor in the block.
Old Nov 3, 2006 | 06:26 AM
Car: 1989 iroc
Axle/Gears: 2.77
good idea to ground it, thanks
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
