timing issue
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
timing issue
im a tigh *** when it come to spending mony i dont haft to spend i went out and bought a timing light so i can set my timing on me car dose anyone know what the spec are for a 305 what the timming should be set at and where the time indacator is on the block.
im trying to do this project by my self with out taking it to a garage and all
Engine: 383 stroker
Transmission: th350
not its not a tpi now im a noob when it come to the lingo and all but it is carbed and all but not factry its a little beefed up
I'd set it on 10deg. See if it pings under load (up hill ect) I reckon thats a good starting point. YOu might be able to get it up around 13 or even 16 if the dizzy has been re-curved before it pings.
theshackle
Sep 17, 2020 08:26 AM
