Oil Pan replacement
Old Nov 3, 2006 | 05:18 PM
larryboz's Avatar
Oil Pan replacement
I have a crack in a oil pan. I have searched and read something you can't replace the pan in a 3rd gen if it is a manual. Is that true? my car is a 92 Z28 305 TPI/5speed and don't want to pull the motor just yet. Any advice?
Larry
Old Nov 3, 2006 | 06:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's true, the bellhousing is too large to let the oil pan out back.
You can remove your tranny, and try to lift the motor up, with a crane (pretty much pulling the motor), but that's really your only bet.
Or some metal reinforced epoxy over the leak, or some other way to plug the hole. But boy, epoxy to hold oil in the motor makes me nervous.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
