what type do i need spark plugs and wires
Old Nov 7, 2006 | 04:04 PM
Carpenters87Irc's Avatar
Car: 1987 Camaro Iroc-Z
Engine: 5.7L
was wandering what type of spark plugs and wires to go with have a 87 iroc-z 5.7L stock except for computer chips and edlebrock E-tech headers. when got header i decided to let jet hot coat them
Old Nov 7, 2006 | 04:14 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Moving this to Tech / General Engine.
Old Nov 7, 2006 | 04:15 PM
subliminal's Avatar
I would go with a set of MSD wires and NGK plugs. Whatever you do DO NOT use the Bosch platinums lots of people have problems with those and theyre expensive.
Old Nov 7, 2006 | 07:11 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
the platinum's you refer to are the platinum 4's ... the 2's are fine.
Old Nov 7, 2006 | 07:29 PM
subliminal's Avatar
they may not have as much problems as the 4s but platinum doesnt conduct electricity as well as good ole fashion ones do. I know alot of people with MSD ignitions have problems with any platinum plugs.
Old Nov 7, 2006 | 07:38 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
I have the 5.7 tpi and run ac-delco plugs with no problems at all & they are $2 each . And yes , a good set of wires is a must
gutted cat
3" dynomax
t.b.bypass
10* timing
tci trans w/2200 stall app.
245/55-16 nitto d/r
2.77 posi
13.71 @ 99mph 1.85 60'
4* timing
13.75 @ 102 1.90 60'
10* timing
Old Nov 7, 2006 | 09:46 PM
safemode's Avatar
Car: camaro rs
I'm not going to argue spark plug voltage requirement differences when you're using an aftermarket coil ignition system to boost the voltage above stock anyway. Platinum is supposed to require more voltage, that's what gives it a stronger spark...and that on top of its durability is what makes it attractive as a spark plug.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
