Starter overheating?
Old Nov 9, 2006 | 09:26 AM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
Whenever I turn my car off and then start it right back up (example: getting gas) the starter cranks really slow, like the battery was low or something, but it starts cold just fine. My friends and I think the starter is just getting too hot. Is there any solution to this? Its a brand new starter and I don' remember having this problem with my old one. Is there a better starter to buy? I don't really want to have to heat wrap the header. I know Longacre makes starter wrap, does it work? Is that my last resort?
Thanks ahead for any help
-Dan
Old Nov 9, 2006 | 11:19 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You can buy a starter heat shield which helps. Little piece of tin for like $12, which guards it from heat.
Making sure your electrical connections are good and clean, and timing is not too high, will also help.
Old Nov 9, 2006 | 12:10 PM
Engine: 383 Stroker
I just went to autozone looking for just such a piece and they don't have it. My timing isn't too aggressive and all the wiring and contacts are new.
Old Nov 9, 2006 | 02:04 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
JC whitney and numerous other companies carry starter "Heat Wraps" and shields that bolt into place.. I found it easier to get the wrap..
I live in AZ, 100+ degree weather is standard
out here, Starter problems are common.. But
usually when a starter cooks, It generally does
not want to move or make a sound at all untill
after it is cool enough. Yours simply cranks, but slowly.. Double check all grounds, and leads.
Back to the heat wrap..It looks like a fire blanket,
kind of a aluminum foil exterior with vel-cro ends.. You simply wrap it around the starter nice and tight.. and it works like a charm.. Im sure shields work just the same but.. more time consuming to install.
Good luck
Old Nov 9, 2006 | 02:30 PM
Engine: 383 Stroker
Thanks for the advice, i'm going to look for some of that wrap. I know its not a wiring issue because when the car is cool the starter cranks as it should. I only have an issue when it is hot.
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
