All of a sudden, no starting - urgent help needed
Old Nov 11, 2006 | 02:32 PM
DracoZK's Avatar
Car: Z28
Engine: 350 L98
Hello,
92 Z28, L98 350, T56.
I left for work this morning, car started no problem. I go to leave work and I get nothing. The engine cranks, fuel pump primes but I get no starting.
Checked the trouble codes, I get 42 45 51. From reading other posts not really sure where and why all of a sudden I get my EST circuit, 02 Rich reading and faulty PROM. I do burn my own chips, but I haven't done anything crazy. I tried switching the chips I had in the car (my previous burns as the chips are works in progress). I even tried using just the basic stock L98 350 chip (I have a hypertech chip that I use for swapping chips). I still got nothing.
I also tried disconnecting the battery, still nothing. Push start - nothing.
Anyone got any advice or leads to get my new large, heavy paperweight working?
Thanks,
Kyle
Old Nov 11, 2006 | 03:01 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Do you have spark? Remove a plug and try starting it with the plug touching the block at the electrode end to see if you have an arc. If not, then try looking at your ignition components.
Apart from pulling the codes, I would be ensuring the car has the three necessary components for internal combustion before getting too technical. A fuel/air mix, a spark, and compression. If it's not even attempting to start or stumble, then one of these must be missing.
Old Nov 13, 2006 | 09:27 AM
eruk's Avatar
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
You might have a plug wire that is burnt or is melt that burnt out ign coil and control module
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
zeitghaist
Aug 18, 2015 07:33 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
