Valve covers dented from underneath
Old Nov 12, 2006 | 04:43 PM
MetalliCamaro68's Avatar
My right side valve cover is dented from underneath like the first two rockers is hitting it. It sounds like it too. Also, it runs rough. What is happening here??? There is only about 200 miles on it after cam install.
Old Nov 12, 2006 | 05:07 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
i had to punch out the valve covers on my 383 cause the scoprions woulds hit
Old Nov 12, 2006 | 05:26 PM
Didnt oil get all over the place?
Old Nov 12, 2006 | 05:53 PM
Stevo's Avatar
Car: Pair of 92 Z28s
punch out as in enlarging im guessing?
you need taller valve covers it sounds like.
Old Nov 12, 2006 | 07:01 PM
I have tall valve covers. It is till running rough. There are new plugs, clean dist cap, new wires, no vacuum leaks. Does this sound like the valves are messed up?
Old Nov 12, 2006 | 07:18 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Whats the lift on your cam? whats the length of your pushrods?
Normally tall valve covers work right up to a .650 gross lift....
Old Nov 12, 2006 | 08:41 PM
TwoChevZs's Avatar
I took my cover off the other day. To find that the metal the that they put below the oil entry was worn off. I have edelbrock valve covers.
Old Nov 12, 2006 | 09:10 PM
I am unsure of the lift on the cam and length of pushrods. I will find out tomorrow.
If the valves are out of adjustment, how do you adjust them?
Old Nov 13, 2006 | 07:11 AM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
you can do it 2 ways:
With the engine running, turn each adjusting nut so that they stop taping...
or
engine off:
Turn the engine over so the the valve is closed, turn down the adjusting but while trying to spin the push rod. When the push rod just starts to begin to be hard, stop and turn it 1/2 more more....
Old Nov 13, 2006 | 08:50 PM
I took it back to the guy who put the cam in. He said it sounded like the problem it was a rocker backing off.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
