350 SBC
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
350 SBC
I have an opportunity to purchase a 350 4 bolt main (block only) for $50.00. According to the seller, the casting implies that it is a 1968 block. He is not sure what it is from. Are all 350's universal? Would that work in a 92 Z28? I have the roller set-up and plan (eventually) to go w/a stroker kit. What should I look for, and where do I look for problems on those blocks (such as cracks) to justify it as scrap or not? Also, is there a way to determine if it has been bored out or not? He is un-sure. Thanks for your help in advance!!
oops, nevermind. He sold it already
Last edited by 25thannivZ28; Nov 12, 2006 at 05:08 PM. Reason: Automerged Doublepost
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
If the engine is complete, take off a head and measure the bore diameter with a GOOD quality caliper. Also use your fingernail to feel how thick the rig is at the top of the bore. It is always better to start with a complete engine. That way you can tell a lot about it's condition when you take it apart. If it is just a block there may be a reason it isn't in use.
As far as cracks, you really need to have a machine shop magnaflux it! I'd make the purchase dependent on the results from a machine shop inspection. Negotiate a deal....
Good luck
Good luck
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Eric-86sc
Aug 24, 2015 09:01 PM
