New timing cover with out removing pan?
Old Nov 13, 2006 | 08:31 PM
rtchaney's Avatar
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
Ok, so I sure that most of the people here have had someone tell them that there was an easier way of doing a certain task. Lets say for example, putting on a new timing cover without removing the oil pan?! That is a new one to me but, if it is possible, definately a consideration. If any one has some good input, please reply.
Old Nov 13, 2006 | 09:00 PM
LT1Formula's Avatar
Almost impossible to do without dropping pan.
Old Nov 14, 2006 | 09:36 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
modify the lip untill it just passes but make sure you keep enough intact to hold the front seal of the pan gasket
Old Nov 14, 2006 | 09:43 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
What are you kidding me? Why does everyone think that this is impossible to do?
I have removed my timing chain cover 3 times since I've had the car.
All you have to do is unbolt the front two bolts on the oil pan to release pressure on the timing chain cover enough to slip it out.
My god, I can't imagine dropping the entire pan just for that
Old Nov 14, 2006 | 11:19 AM
rtchaney's Avatar
Car: 89 RS
Would you mind elaborating on the process that you did to accomplish this task? It could prove to be very helpful to me.
Old Nov 14, 2006 | 01:44 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
It was done on my car , but the guy didn;t do it right and I spewed oil out the front every time I had to stop. But it's ben done. Like said above just loosen the oil pan
Old Nov 14, 2006 | 09:38 PM
REMOVAL
Unbolt the timing chain cover
Unbolt the front two bolts on the oil pan (one on each side), this will loosen the pan enough in the front to get the timing chain cover out.
Slip the timing chain cover out, you might have to tilt it away from the block to get it out.
INSTALLATION
Make sure you get a new gasket for the lip of the timing chain cover before you put it back on.
Load said gasket up with blue RTV, and make sure that the gasket is seated properly and centered.
Tilt the cover back into place and screw it back in hand tight
Ensure the cover is seated right in the oil pan (just make sure it is pressed in all the way)
Screw the two oil pan bolts back in
Screw the rest of the timing chain cover bolts in all the way. Dont torque them down too far, this is stamped steel you are securing remember, if you tighten them down too much, you will warp the cover and cause gaps that will leak oil.
Old Nov 15, 2006 | 03:16 PM
rtchaney's Avatar
Car: 89 RS
thank you
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
MY87LT
Aug 17, 2015 08:43 AM
3rdgenparts
Aug 8, 2015 07:09 PM
