noisy valve train
Old Nov 13, 2006 | 09:30 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
noisy valve train
just finished a re-build and ran it for the first time. the valve train is extremely noisy any ideas?
comp cams retro hydraulic roller lifters, proper length comp cams push rods, hardened guide plates and harland sharp 1.5 roller rockers.
thx
jeff
Old Nov 14, 2006 | 09:29 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
take the valve covers off and look for clearance issures with the stud and boss.
also look at the hole the pushrod goes through
all while turning the motor over by hand
Old Nov 14, 2006 | 02:53 PM
jjlabinski's Avatar
Engine: shinny 350
push rods rub against guide plates I was told this is normal?
Old Nov 15, 2006 | 05:28 AM
jamon8's Avatar
Engine: 350 tpi
sometimes you have to make the hole bigger in the head where the pushrod comes through.
nothing to do with the guide plates
what size cam and what heads are you usin
Old Nov 15, 2006 | 05:24 PM
jjlabinski's Avatar
Engine: shinny 350
plenty of clearance with rods and heads
push rods do rub on guide plates
cam is comp cams 276
compression 10.5:1
Old Nov 16, 2006 | 08:11 AM
jamon8's Avatar
Engine: 350 tpi
check your retainer to valve guide clearance
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
