timing mark rattles a bit, normal?
Old Nov 14, 2006 | 06:42 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
with a lot of ur help,
I fixed my backfiring problem by loosing up the rocker arm a bit.
while at it I put a new 180 thermostat.
now my temp in the cluster never reads over like 180.
and when i drive for a while, my idle starts to get sluggish(doesnt stall).
I thought my timing was off or something so I tried adjusting my timing,
and noticed that when Im aiming the damper with my timing light
the notch kind of rattles a bit.
is this normal?
my timing light is a craftman piece that I bought for 60bux
and inductive type or something.
not too much of a fancy one, lemmi know guys thanks!!
Old Nov 14, 2006 | 07:08 PM
Damon's Avatar
You mean the timing jumps around a degree or so? That's normal with a motor that's got some miles on it- the timing chain gets loose and can let things float around a little.
midge54
Dec 27, 2019 04:14 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Thirim
Aug 9, 2015 06:19 PM
mustangman65_79
Aug 8, 2015 12:07 PM
