TPI map issue I think
Old Nov 15, 2006 | 04:15 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my buddy is having issues with his tpi vehicle, it is a speed density setup. problem is when he fires it up, it hunts for idle, raises up and real low in the rpm about 3 times before it settles, if we unplug the map sensor, it starts up just fine! we borrowed a new map sensor from work, plugged it in real quick, and the same issue with the hunting idle. but of coarse, if we unplug it, it fires up just fine and idles perfectly. what could cause this?
Old Nov 19, 2006 | 11:14 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
It's just a little too lean, that's all. Could be lots of carbon absorbing the fuel at first startup. Could be ECT sensor problem. Could be a lot of things. Check the basics first, like base timing, and fuel pressure.
Is it stock?
Old Nov 19, 2006 | 11:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Yea it's stock. Thanks for the tips I will pass it on. He mentioned a leaking egr gasket ? Would that effect it at all once he fixes it?
Caspar
Jun 19, 2016 11:19 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
