Ignition Problem
Old Nov 16, 2006 | 10:12 AM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
Ignition Problem
I have a 87 camaro, when i turn the key forward there is no beeping noise or the gauges don't zero out. Its like the batterys dead, i put a new battery, but did not do nothing. all the lights work. I already swaped out two electronic ignition switchs and still nothing works. Is there a realy to the ignition wireing or any other thing that causes a short, i have not installed anything electronical. If so does anyone have a diagram or picture on how to fix this. Please help!!!!
Old Nov 16, 2006 | 11:55 AM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Check your fusible links.
Old Nov 16, 2006 | 12:17 PM
Skull88's Avatar
Engine: 305 cu. in.
Where would those be located at, do u have a pic
Old Nov 16, 2006 | 03:00 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Some off the starter. Have you checked your regular fuses as well as your actual connections to the block and starter?
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
