what does this mean?
Old Nov 17, 2006 | 03:53 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
what does it mean when your car shuts off randomly, doesnt throw up a check engine light, you have massive oil leaks from the oil pan, oil pressure sending unit and rear seal? o yeah and shoots the oil dipstick out?
Old Nov 17, 2006 | 07:57 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
sounds like way too much oil pressure... caused by "blow by" or way to much oil.... is there oil shooting out of the dipstick?
Old Nov 17, 2006 | 08:09 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yeah, not good. Like was said above sounds like alot of blowby. Rings are most likely shot.
Old Nov 17, 2006 | 08:39 PM
Car: 92 Camaro
Axle/Gears: S60 373
piston rings are shot? But I was short 2-3 quarts of oil how could I be overdoing the oil?? I am not trying to argue just trying to understand
There was some oil that was sprayed on the passenger side of the engine compartment
Last edited by 89formula350b2l; Nov 17, 2006 at 08:40 PM. Reason: Automerged Doublepost
Old Nov 17, 2006 | 10:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Replace your PCV valve (or get one if you don't have it) and it will likely help the situation alot, if not fix it completely.
Old Nov 17, 2006 | 10:08 PM
Car: 92 Camaro
Axle/Gears: S60 373
well what is the likelyhood i messed something in my engine up like my rings or soemthing?
Old Nov 17, 2006 | 10:17 PM
Car: 92 Camaro
Axle/Gears: S60 373
other than ripping apart the block how can i check to see if the rings are shot?
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Only a compression test will tell.....
Old Nov 17, 2006 | 10:48 PM
Car: 92 Camaro
Axle/Gears: S60 373
ive been dreading that
Old Nov 17, 2006 | 11:12 PM
Air_Adam's Avatar
Change your PCV valve... one of its PRIMARY PURPOSES is to help ring seal. Put one in.
Old Nov 18, 2006 | 09:21 AM
Car: 92 Camaro
Axle/Gears: S60 373
you mean a new one?
Old Nov 18, 2006 | 10:00 PM
ChrisColeman's Avatar
Jesus. Take it to a mechanic. Guys doesnt the ECM shut down the engine if it detects low oil pressure? PCV valve is not gonna help the random shut downs. How long did you run it 3 quarts low? You drive around with a leaky pan and rear main?
Old Nov 18, 2006 | 11:44 PM
Car: 91 RS
Engine: 350 vortec
as far as i know the ecm will NOT shut down with low oil pressure as i have broken the pressure sensor and had to drive it to napa for a new one and a PCV will help with random shutdowns caused by blow by which is what this sounds like except for the oil leaks which were either caused by this problem or were already there and have worsened because of this...
Old Nov 19, 2006 | 12:47 AM
Air_Adam's Avatar
PCV valve helps the rings to seal properly. Thats what they are there for (among other things). The engine was built with certain parts and specs assuming there would be a PCV valve in the mix. Put in a new PCV valve. If it doesn't work, you are out maybe $5 and a few minutes time, so whats there to lose?
Old Nov 19, 2006 | 01:52 PM
Car: 92 Camaro
Axle/Gears: S60 373
i didnt know where the leak was coming from....so i took it to a shop where they lifted it up and i saw where it was leaking from....i put ab 3/4 quart in two days before i took it to the shop.
what ab a rubbing/metal on metal noise from the engine? that just popped up.
Also there is smoke coming out of the dipstick shaft once I remove the dipstick.
and my oil pressure hasnt gone below 20psi, even at idle. highest was 45ish when i first start the car.
Old Nov 19, 2006 | 04:54 PM
Car: 92 Camaro
Axle/Gears: S60 373
the oil leak was there first and then recently it started shutting off on me
Old Nov 19, 2006 | 05:58 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Shutting off randomly could be all sorts of things from a bad MAF to a bad ground. Trying to guess with the crap you provided is about the same as me just making up a problem for you to fix.
Start by doing a bloody compression test and see what you get. Fix the oil leak and then go from there.
Old Nov 19, 2006 | 07:14 PM
Car: 92 Camaro
Axle/Gears: S60 373
took a look at the grommet for the pcv valve....looked like it was shredded. went to advance auto and got a replacement the pcv valve fits snugly now, didnt drive it tonight bc so late but will drive around tomorrow and will see if still leaks and will fix leaks then.
Old Nov 20, 2006 | 01:34 PM
Car: 92 Camaro
Axle/Gears: S60 373
engine is dead....firebird dead......RIP
Old Nov 20, 2006 | 01:58 PM
Ahh , RIP I live in Roanoke man. Ive got an old 92 LO3. Fairly low miles if interested.
Old Nov 20, 2006 | 02:37 PM
Car: 92 Camaro
Axle/Gears: S60 373
thank you but no, i think i am going to build it...better than before
Old Nov 20, 2006 | 09:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You know my advise
Old Nov 21, 2006 | 10:33 AM
Car: 92 Camaro
Axle/Gears: S60 373
yes sir.....i already talked to jamy he said he can hook me up i am just waiting for a price check from him...and then it will be alive again!
