MSD-8500???
Old Nov 23, 2006 | 01:26 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
MSD-8500???
Will a MSD-8500 kit work with our cars?
My motor is carbd and from what it sounds it would work, but summitracing.com states that I would only work with motors up to the 80's?
http://store.summitracing.com/partde...0&autoview=sku
Just need no know if it worked, And if so...How well did it work for you?
Thanks in Advance
Old Nov 24, 2006 | 10:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The .pdf instructions show installation with the 7-pin module. Sounds like it works.
Old Nov 24, 2006 | 11:41 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
My motor is carbd and from what it sounds it would work, but summitracing.com states that it would only work with motors up to the 80's?
Probably because it's for non-computer controlled engines. Our cars (3rdgens) are computer controlled.
Old Nov 25, 2006 | 07:41 PM
five7kid's Avatar
Again, the instructions refer to how to hook it up to an ignition with a 7-pin module. That's the computer-controlled large-cap HEI. '82-'86 carb'd (US-delivered) had that system.
Old Nov 26, 2006 | 01:19 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
True, the installation.pdf at the bottom of the page is correct.
I was refering to the Summit application search results from the link MyFast3rdgen provided.
A search may lead others to the same conclusion.
I browsed by brand name.
Brand: MSD Ignition
Department: Ignitions & Electrical
Make: CHEVROLET
Section: Ignition Components
Part Type: Ignition Box and Coil Kits
Model: CAMARO
Browse By
Year: 1974, 1975, 1976, 1977, 1978, 1979, 1980
Engine Size: 5.7L/350, 5.0L/305, 4.4L/267
And by Make & Model, MSD wasn't even in results.
Make: CHEVROLET
Model: CAMARO
Year: 1986
Browse By
Brand: Crane Cams, Accel
Engine Type: L4, V6, V8
Engine Size: 2.8L/173, 2.5L/151, 5.0L/305
Circuitry: Analog, Digital
Ignition Box Output: Inductive, Capacitive discharge
MSD doesn't list the 8500 kit on it's product page and a seach for 8500 yields only an image of both non-ECM and ECM systems.
Product number range 8423 thru 8739 http://www.msdignition.com/1media_imagesB.html
Here's the image. http://www.msdignition.com/media/images/8500_kit.jpg
Old Nov 26, 2006 | 02:03 PM
Car: Trans Am
I thought it pluged in outside the cap...not in side the cap, or....i'm just really confused now.
The disb. I got on my car now is not computer cotrolled, however I do not know how many pins I got,
Old Nov 26, 2006 | 09:04 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Can you post a picture of what you have, internals as well?
Old Nov 26, 2006 | 10:50 PM
five7kid's Avatar
That would have been good to know from the beginning. If that's the case, then the earlier applications they listed do apply to you.
If you have a "standard" large cap HEI, it's a 4-pin. Bypassing the module is actually a good thing.
