NEW Eliminator AFR's are HERE!
Old Nov 27, 2006 | 08:42 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
DAMN!...it took almost 5 months to get these puppies to my door...I hope the wait is well worth it.
Here's some info, they weigh 27.5lbs each..they are 195 L98 angle plug heads with 65cc's upgraded rocker studs to ARP to work with my pro magnum rockers...I got the rev kit to go with it...total price came out to $1675.11 and were ordered on July 14th and I just got them today..
they were inspected to make sure there was not going to be a problem with the valve issue people have been reading about...that took an extra week.
anyways heres some pictures..packaged very well.
Attached Thumbnails NEW Eliminator AFR's are HERE!-dsc02019.jpg   NEW Eliminator AFR's are HERE!-dsc02021.jpg   NEW Eliminator AFR's are HERE!-dsc02022.jpg
Old Nov 27, 2006 | 08:44 PM
more
Attached Thumbnails NEW Eliminator AFR's are HERE!-dsc02023.jpg   NEW Eliminator AFR's are HERE!-dsc02024.jpg   NEW Eliminator AFR's are HERE!-dsc02026.jpg
Old Nov 27, 2006 | 09:05 PM
I want to post more pics..but it wont let me...
Old Nov 27, 2006 | 09:25 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
sweet...do you have any flow numbers for them?
Host the pics on photobucket.com.
Old Nov 27, 2006 | 09:48 PM
http://s147.photobucket.com/albums/r295/wishmaster8/
flow numbers are according to AFR
.200 137cfm 110cfm
.300 194cfm 158cfm
.400 240cfm 190cfm
.500 270cfm 207cfm
.550 280cfm 211cfm
.600 286cfm 215cfm
hey thanks for letting know about photobucket
Old Nov 27, 2006 | 10:54 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Flow numbers are very similar to the canfield/jegs heads. I wonder if its the same design.
Old Nov 28, 2006 | 06:23 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
They look great! can't wait tell mine get here, I ordered the 75cc head with strait plugs but what is this about a valve issue problem you been reading about?
Old Nov 28, 2006 | 06:34 AM
go to corvetteforum.com and do a search for afr heads...and its all in there...TOny from AFR responds in the thread.
Old Nov 28, 2006 | 06:52 AM
Tony89GTA's Avatar
Car: 89 GTA
Just found it here http://www.chevelles.com/forums/showthread.php?t=151725
Old Nov 28, 2006 | 11:55 AM
Guest
Guest
Posts: n/a
Well thats a large step past their previous offering... much cleaner casting and machining.
I wonder if those are going to respond well to porting or not?
Funny reply on that link...
Old Nov 28, 2006 | 12:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
wow thoes are tiny looking ports.
Old Nov 28, 2006 | 01:19 PM
what do you mean tiny? what size are they suppose to be? what are they suppose to look like?
I dont care what what they look like or anything..as long as they perform like they are suppose to Im fine with that!.....Im not waiting around for anything else...I want to get this motor done and on the road...I waited to long for these freakin heads
Old Nov 28, 2006 | 01:29 PM
Demon355's Avatar
Those look sweet!
Old Nov 28, 2006 | 07:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Good selection of heads you bought. Probably the finest out of the box heads you can buy today for our cars. Just give them a proper cam, supporting mods and hold on. Hahaha.
Old Nov 28, 2006 | 08:00 PM
yeah I hope!....now I gotta get this thing together and see what happens when I hit the gas...LOL..Im hoping to be in the 11's..I hope or at the least very low 12's
Old Nov 29, 2006 | 11:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
vortecs are in the high 11s, i would hope for 10.90s honestly. unless you're choking the motor with a TPI or something like that. Get a nice 4000 stall and 4.10 gears and hold on. .6xx/.6xx lift cam and you'll be golden. Look at IHI's combo and it was 3600 pounds too for race weight
Old Nov 29, 2006 | 11:30 PM
Ive already got all my stuff..Im gonna be running a HSR intake....cam is custom made from www.camshaftinnovations.com 226/232 535/537 113.5 LSA thats with 1.52, Im thinking of going to 1.6 but I dont think that would be that big a difference..Jay says to trust him it will go in the mid 11's
my race weight should be about 3400lbs or less with me in...full street trim...its a daily driver...everything in my sig except a 383 to boot!
Old Nov 30, 2006 | 06:44 PM
Car: 1989 GTA
Engine: 369 TPI
Go with the 1.6 rockers. Remember "lift is your friend". Especially with those heads. The valves will be off the seat quicker and that will help fill the cylinders in all the lift ranges. The valves will be open longer. It's a win win situation especially in your case.
Old Nov 30, 2006 | 07:27 PM
how much will the 1.6's change my cam profile? does it just change lift or does it affect everything in the way the cam will act..
thanks
Old Nov 30, 2006 | 08:48 PM
Guest
Guest
Posts: n/a
It will change the duration, but not enough to talk about.
Old Nov 30, 2006 | 09:39 PM
xpndbl3's Avatar
Car: 1984 Z28
i'd say a bigger cam, duration wise and lift wise. If not run the 1.6 rockers at least to get the most flow out of those heads.
Old Nov 30, 2006 | 10:09 PM
I cant afford another cam..this one cost me $419.00
I may call Jay up and ask if he would trade my new 1.52 for a set of 1.6 pro's
I dont want a cam so big that it would kill all my lowend and kinda bog before the power comes in. He told me I should see 400 or so torque at 4000rpm and keep a flat torque curve thruout.
AFR says that if I went to 1.6's I would see maybe a gain of 15 or so HP..
Pac J
May 17, 2020 10:44 AM
ULTM8Z
Oct 2, 2015 01:25 PM
