What are the first mods that I should do?
Old Dec 1, 2006 | 03:08 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
See Sig:
Anyways I bought it with an aftermarket exhaust system... I don't know what it is though, I am convinced of getting new gears and a shiftkit?
I heard Transgo is better then B&M, and that I should have a 3" exhaust, how do I tell that, Do I measure the tips or something?
I want to keep my 305, but I need more power so what should I do to it?
-Thanks
Old Dec 1, 2006 | 03:19 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
B and M shift kit is junk.
Trans Go kit actually fixes the known issues an improves performance and reliability.
As far as mods, do all maintenance issues before touching any mods whatsoever.
Fix leaking intake gaskets and worn valve stem seals. Make the car 100% correct electrical and mechanical than worry about improving upon it. Plus you will also know what the true benifit was of what u did.
First mod after getting everything 100% working would be to leanr PROM burning like here on our PROM board.
Some might argue this, but I'm just going on what I have learned.
later
Jeremy
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
