MSD 6al box installation location...
Old Dec 2, 2006 | 02:09 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Has anyone found a good place to mount the MSD ignition box other than the crowded engine compartment??
I don't know if there's a hidden spot under/behind the dash firewall area or between the front bumper & radiator??? The engine compartment is overcrowded as it is without cramming in anything else. Nitro
Old Dec 4, 2006 | 06:12 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
I mounted mine where the factory computer was, but there are some other ideas in this thread.
https://www.thirdgen.org/forums/fabr...tall-pics.html
Old Dec 5, 2006 | 06:28 PM
smallblock383's Avatar
Car: 1991 Z28
Engine: 383 TPIS Mini Ram
Transmission: D&D Perf Viper/GM T-56
Axle/Gears: 3.73's Eaton Posi
I installed mine under the passenger seat....seat doesn't get used much in my car so its was out of the way. I recently re-located my battery to the back of the car and ended putting it there instead. Now its a little easier to get at the rev chips.
Old Dec 5, 2006 | 08:41 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
I've removed my washer bottle, so I built an aluminum bracket, and bolted
it right above the charcoal cannister. I also am running a 12v muffin fan
on the bottom of the bracket, and will be running a fresh air tube through the
bottom of the car to keep it cool. Looks great, and is out of the way.
Old Dec 6, 2006 | 12:54 PM
neagan's Avatar
Location-Location-Location....
Great! I've been scratching my head for an alternative location; not that I need a spotless engine compartment, but I definitely don't want to add to the factory clutter.
Thanks Guys! Mucho Appreciated!!!! Nitro
Old Dec 7, 2006 | 10:20 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I mounted mine partially under the dash on the passenger side. The only problem so far is that I can hear it (and it's a little annoying), so I might mount it under the passenger seat like smallblock383 did...
Old Dec 10, 2006 | 01:40 AM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
MSD 6AL box location
Hey Neagan,
About your MSD box location - I installed mine under the rear seat
drivers side. Ran the wire under the door sill plate.
"That's not a vernacular! That's a derby!
Jerome Howard - 1936
Old Dec 11, 2006 | 09:25 AM
NiteStar's Avatar
Car: 92 formula w/t-tops
Engine: 350 (L98) 5.7 TPI
Transmission: 700-R4
I mounted mine near the hood latch in front of the radiator. Been there for 7 years with no problems.
Old Dec 25, 2006 | 12:34 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Old Dec 27, 2006 | 06:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
Its best to keep the wires on the box as short as possible and I know that cane behard considering there is not many places under the hood t mount these boxes without it looking tacky. I mounted mine where the charcoal canister use to be. it is low and out of sight and it gets some fresh air to keep it somewhat cool.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
