Really debating new lifters and pushrods
Old Dec 12, 2006 | 10:13 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Well guys, my LO3 is coming up on 180,000 miles soon and I have a feeling that the roller rockers needed other new stuff to work properly. I think my pushrods are mushroomed because when I tighten a rocker, the puhrod will spin free then at some point get touch, then spin free again. I know that fresh valvetrains dont do this. Also I figure if I am swapping intakes anyway I should tackle this because I wanna start fresh. The roller rockers keep coming loose because they will be tight on one part of the pushrod, but if it spins any, the lash is thrown off.
So guys what do you say about some summit roller lifters and some comp cams stock length pushrods? CCA-7808-16 pushrods?
Old Dec 12, 2006 | 10:58 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
If they are roller lifters, you probably do not need new ones. Just remove them and clean them up in some paint thinner or kerosene. Soak them and try to get as much oil out as possible.
Then soak them in oil just as you would brand new lifters.
Pushrods are cheap, might as well replace them.
Old Dec 12, 2006 | 11:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is it just me, or does 7.195" sound a bit too short?
Old Dec 12, 2006 | 11:33 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
remove the pushrods and roll them on a flat plate of glass.
I'll bet some are bent.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 6, 2015 03:51 PM
