Running Lean After Rebuild
Old Dec 18, 2006 | 04:52 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay, the Camaros been on jack stands for about a month now, and it's finally running again. Unfortunately, it's throwing a code 44 (running lean) at me and running a little rough at idle. Here's what I did: replaced the rod bearings, piston rings, had heads cleaned and resurfaced, and replaced all gaskets from the heads up. I also added an open element air cleaner.
Now the car was running just swell a month ago before the rebuild. So why would it act up now? Can the computer not compensate for the air cleaner and cleaned heads? Can I ramp up the fuel pressure myself? Thanks in advance.
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Aug 16, 2015 08:01 PM
sreZ28
Aug 14, 2015 07:48 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
