nned info on these polymer dist. gears
Old Dec 20, 2006 | 10:27 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am about to put a stock dist. back in my car but I need to buy a polymer gear first. What size gear do I need? is it the .491 size? or is there a smaller size one for the distributors with the external coil? I have a MSD pro billet dizzy 8366 that needs a serious rebuild (shaft is bent) and I would love to use it after its fixed but I need the car runing ASAP. I really dont want to buy a polymer gear at $120 for a stock dizzy and then have to buy another one to fit the MSD dizzy. Do they sell shims for these?
Old Dec 21, 2006 | 02:37 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I am curious as to how your dist shaft got bent? The only time I have seen that happen is when a motor locks up at high rpm.
Old Dec 21, 2006 | 02:42 PM
BOTTLEDZ28's Avatar
Transmission: A4
no idea.I will find out more when it goes to MSD. the relutctor ring on the top of it is .0070"off on some of the tabs. its bad enough where it causes a miss fire on the same 4 cylinders after time.
junkcltr
Aug 2, 2019 11:12 PM
apo_bailon15
Mar 28, 2016 05:20 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
db057
Aug 22, 2015 08:17 PM
