What do these spark plugs tell you?
Old Dec 24, 2006 | 05:40 PM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
I thinkk they tell me that i got one of my two injectors headed south. The way they are laied out is the way they came out of the motor from front to back...
Old Dec 24, 2006 | 05:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
looks like you have some oil getting into a few cylinders...
Possibly rings or valveseals...
Old Dec 24, 2006 | 05:43 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
It looks like 4 of 8 have rich condition and your rings are weak, the other four look old.
Old Dec 24, 2006 | 06:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
1/2/5/8 look like they are getting some oil, the other 4 look decent.
Old Dec 24, 2006 | 10:14 PM
y5mgisi's Avatar
i have about 50 miles on the motor and plugs
Old Dec 24, 2006 | 10:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm guessing oil passed the rings then, or valve seals/guides. they all look alright other than that, not entirely as lean as it could be though.
Old Dec 24, 2006 | 11:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Those are the plugs you put in the car to fire up the new motor? I wouldn't even bother trying to read those, breaking in the motor will give all sorts of weird plugs as things seat. Unless you see something drastic ( I don't ) I wouldn't lose sleep over it. Drive the ***** off it and seat the rings etc.
I'd just read them after a few hundred miles
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
