1989 CAMARO RS TBI 305 ROUGH IDLING
Old Dec 25, 2006 | 10:40 PM
1989RS305's Avatar
My 1989 Camaro Rs 305 Tbi Has A Problem I Dont Know What It Is Sometimes When It Is In Reverse It Dies Also It Seems Like The Car Chokes When Going At Low Rpm's It Is Really Weird It Ssometimes Dies When I Stop Only Sometimes I Dont Know What It Is I Might Think It Is The Iac Or The Tps I Am Not Sure Or I Think There Is A Vaccum Leak Please Please Is There Anyone That Know What The Problem Is If U Don Can U Tell Me Please Any Ideas Of What It Can Be Can U Tell Me Please Ok Weel Thanks
Old Dec 26, 2006 | 12:44 AM
formula2432001's Avatar
If you have not already fixed this problem I might be of some help. I have a 1988 Firebird Formula, the stock engine was a 305 TBI I have had alot of problems with that set up. My last problem was the same as yours. When I first started it up, she acted as if it was not wanting to idle correctly, I could rev the engine a little and this would stop, and everything was fine. It grew into a larger problem. It began to code when I turned the on, it would not idle, it would not start. I went to the local auto parts house, and picked up an O2 sensor and a computer, both we bad parts. Went back picked up another set and the computer was bad, I found that out after taking it to my local Chevy dealership to be placed on the machine. The machine said that computer was bad as well and I told them to order one. After that the car would ilde but ran horrible and I finally went to the dealership and bought and O2 sensor and the problem was fixed. This might not help you but if you are at a loss to what to do as I was, try the O2 sensor. In the tech section they have alot of information about the O2 sensor, it was very helpful to me in my time of need.
Old Dec 26, 2006 | 06:40 PM
1989RS305's Avatar
well thanks for that i will try that thanks i will let u know if it woeked
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
db057
Aug 22, 2015 08:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
