My Smog Pump Bolt Wont Come Off!!!
Old Dec 28, 2006 | 02:32 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I tried taking my smog pump off today and one of the bolts is seemed to be wedged on the pulley pretty good. I have tried a cheater bar and of course i left the belt on there. There just isnt enough tension on the pulley to keep it still. I have tried holding the pulley with my hand. Any suggestions would be most helpful or i will just i have to live with that parasitic device.
Old Dec 28, 2006 | 03:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Put one of the other bolts back in the pulley - maybe both of the other ones - then use them with rachets (or wrenches) as a hold against the one your trying to remove. The others will tighten really tight, but since you got them out before, chances are you can get them out again. I had one that was a PITA too, and this worked for me (along with a shot of PB Blaster and the time to let it soak in).
Old Dec 28, 2006 | 07:19 PM
Damon's Avatar
Impact gun
Old Dec 29, 2006 | 02:30 PM
Thanks camaronewbie i tried your suggestion and i got that SOB finally off. Im lucky i didnt get those things stuck in there as i was just about to strip those dumb@#$ Torx bolts. Why does GM have to use those stupid star bolts. THANKS and HAPPY HOLIDAYS
Old Dec 30, 2006 | 08:34 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
take the whole braket off and use some air tools and drillin
mine was one of the worst bolts ever
thats what happens when you put a steel bolt in aluminum
Glowsock
Jul 24, 2025 03:15 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
