thinnest head gasket for 305
Old Dec 31, 2006 | 12:28 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what can I use in my 305 that will give me a bit more compression and will be durable enough for garage queen street use.
its 30 over and I know I have seen head gaskets for 350 that are quite thin but I was not sure if I can use these on a 305.
Old Dec 31, 2006 | 01:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can use them. The diameter will be slightly larger than the stock 305 gasket, but it won't make a significant difference. A thick 305 gasket will certainly be worse. Most aftermarket kits use the same gasket for 305 or 350, anyway.
Old Dec 31, 2006 | 01:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A factory steel head gasket is about 0.018"
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
