keeeping it running
Old Jan 3, 2007 | 12:06 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
keeeping it running
what can i do to get my car to stay running the first time i start it up?
i dont drive it much but my 86 tpi trans am immediately dies/stalls within 5seconds after starting it up the first time.
but magically the second time it always stays running and idles beautifully.
any ideas?
Old Jan 3, 2007 | 01:08 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Check the fuel pressure on the rail. Either you have a weak pump or a plugged fuel filter.
Old Jan 3, 2007 | 11:30 AM
Bobby_80s's Avatar
Axle/Gears: no idea
weak fuel pump? Shouldn't either of those 2 problems show problems while driving? the car runs great on he second turn of the key. I will definately have both checked or replaced. The fuel filter was checked and was told it looked fairly new. But after putting a lot of fuel cleaner it may have kicked up a lot of junk from the old old gas and clogged up the filter a little. I also considered the fuel pressure regulator giving a small leak of fuel in the engine while off and in a way drowning the engine and when i first start it up its almost clearing its throat. I know nothing of the fuel pump.
if i needed to replace the fuel regualtor...where could i go to get a nice better than stock? I've seen soem people on here with nice shiny poilished up aftermarket ones. I'll ask around the other threads.
Thanks for the suggestions. If you can think of anything else don't hesitate.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
