vacuum lines??!!
Old Jan 7, 2007 | 05:32 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
vacuum lines??!!
i need help , i'm putting a 305 tpi setup on my l03 but i don't know where the vacuum lines are supposed to go, the only one i have is for the fuel pressure regulator to the plenum, what is the other nipple on the plenum for? and the egr valve? and everything on the throttle body? any pictures to explain would be greatly appreciated. thanks in advance
and how about the line that goes to the brake booster?
Old Jan 7, 2007 | 06:17 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Hard to take good pictures when its pitch black out but these should get you started. Also, these are of a 350ci TPI, yours could be different?
EGR to the intake manifold between the runners on the driver's side:
Top port on the throttle body goes to the PCV Valve. Also, in the bottom of the picture you see the heater control valve. This gets vacuum from one of the vacuum hookups near the bottom of the distributor.
Bottom port on the Throttle Body goes to the valve in the next picture, not sure what it's called. Note: there is a third port below the two vacuum lines on the throttle body, coolant runs through this from the heater valve, I have mine bypassed because I never drive in cold temperatures.
This valve is hooked to the canister right behind the drivers side headlight. The smaller of the two connections towards the rear of the car on this valve gets vacuum from the other port near the bottom of the distributor.
The Forward most port on the rear of the plenum gets hooked to the fuel pressure regulator, the port behind it is for HVAC, mine is plugged off, not sure where this should be hooked to.
Here's a blurry *** vacuum diagram you can try to read if you like:
Old Jan 7, 2007 | 09:16 PM
johnnyboy's Avatar
thanks for the help, i'm pretty sure all the vac lines are the same. hopefully some more people will post too
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
