Loud Knocking Sound When car is on idle, stops when put into gear
Old Jan 7, 2007 | 09:18 PM
mrfrankmrfrank's Avatar
Car: 1989 Iroc-Z Camaro
Engine: 5.7l Supercharged 350
I'm looking to perhaps purchase an 89 iroc z. The body is in amazing shape no rust or dents, the interior is mint. This is a nice car. The seller has put a lot of money into performance parts into the vehicle and is now selling the car because he is disgusted at how much money he put into it just to watch it die.... The seller put in a new rear suspension, headers, exhaust and a supercharger. He took the car out a few times after the install of the supercharger and he started to hear a huge knocking sound. I just looked at the car today and it starts fine. The noise is so loud it sounds like there are a million nails in the combustion chamber. The noise appears to be coming from the back of the engine, closer to the driver side near the firewall. it is a rythmic knocking noise. The second the car is dropped into gear, the noise stops. You can rev the car up as high as you want and it sounds great. The seller said he checked the flywheel and didn't notice a crack. I figure there is no way it can be a rod knocking because even when the engine is reved up in neutral the knocking gets maybe slightly less noisy. any help please, this car is mint and i want it.
Old Jan 7, 2007 | 09:27 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Sounds like a cracked flex plate (commonly erroneously referred to as a flywheel).
The crack would likely be at the crankshaft mounting bolts and extremely hard to see (but not impossible) without pulling the transmission. Usually caused by engine/transmission misalignment it, diagnosis can be confirmed by unbolting the torque converter, pushing it back, and starting the engine; the knock will go away.
Good Luck.
Old Jan 7, 2007 | 10:31 PM
Thanks for the fast response. I'll make sure to use your recommendation to diagnose it. Any more ideas are welcome and i'll keep you guys updated.
thanks again,
ryan
Old Jan 7, 2007 | 10:34 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
check the torque converter bolts, even if they are still there they could be loose which could cause a knocking sound. as i recall when it happened to my car, it started like that, then would knock while driving at low speed ie 10-15 mph
Old Jan 7, 2007 | 10:40 PM
thanks guys, keep the ideas coming. you guys are amazing for the help
Old Jan 8, 2007 | 06:49 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
wrist pin or lifter maybe
Old Feb 16, 2024 | 11:58 AM
Cztheday's Avatar
Re: Loud Knocking Sound When car is on idle, stops when put into gear
I have the same issue, I changed out the fly wheel and torqued everything to spec.
any other thoughts? Could it be the torque converter?
Old Feb 17, 2024 | 08:57 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Id recommend starting a new thread, as this one is almost old enough to vote. That said, if you changed the flex plate and the noise remains, you can unbolt the three converter bolts and see if the noise is still present. If it is, it's very possible main bearing.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
gwade12
Aug 8, 2015 08:17 AM
