Head Bolts
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
Head Bolts
how many ft/lbs do i have to put on the head bolts when i put the heads back on thx
1990 camaro iroc-z 5.7l tpi
60-65 ft-lbs
Whatever you do, DO NOT overtorque them! That is guaranteed to produce a leak.
You MUST use sealer on the threads, on all of them, since all 17 on each one go straight into the block water jacket. Use the Permatex/Loctite thread sealer with Teflon, I can't recall the part #, comes in a little tube on a card. Put it on the threads, and put some on the underside of the bolt head. It makes an excellent lube.
Tighten them in stages; like, 35 ft-lbs all the way around, then 45, then 60. Final torque reading should be taken while the bolt IS TURNING; I shoot for 60, and since the bolt is still turning, it ends up at maybe 62 or so. Go all the way around the sequence a couple of times, you'll almost certainly come across a couple of loose ones. I prefer a beam or dial type of torque wrench, ABSOLUTELY NOT a clicker. Those are good for some things, but not this.
Most likely, the old ones are fine.
Clean the threads with a wire brush, and lacquer thinner; use a tap to clean all the bolt holes in the block.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 25, 2015 12:54 AM
