Delite AC/ Compressor 87 IROC
HI USA
I want to delite my AC/Compressor from my 87 /305 IROC.....,i have multiple belts the AC works with the steeringpump.
What kind of shorter belt did i need...can anybody help me...
Thanks Michael (germany).
Transmission: 4L80E/4L80E
Just take the AC belt off. Use the PS belt for w/AC application by itself.
I did that for a couple of years. No problems. The AC belt doesn't contribute that much to the PS drive.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Confused... does you car have 1 drive belt (serpentine setup), or several V-belts?
Up through '87 there were multiple belts. '82-'85 were all V belts. '86 & '87 had a flat multi-groove belt for the alternator, which also went over the water pump (and crank, of course). There was a V belt for the air conditioner, which went over the 2nd groove of the power steering pulley, as well as crank and water pump pulleys (4 pulleys total, the only such belt in the system). Behind the air conditioner belt is another V belt that goes from the crank pulley to the back groove of the power steering pulley. Finally was a belt that went from the front of the water pump pulley to the A.I.R. pump.
If you only have one belt going over the air conditioning compressor and the power steering pump, you've got one belt missing. Your power steering pulley has two grooves, right? If not, it's a thrown together system, and you're going to have to find a belt that goes over the power steering pulley one way or another.
Car: 87 Camaro IROC
push the power steering pump as close to the centre of the car as possible, then measure with a piece of string, run it through the crank pulley and through the power steering pump pulley, you might get a measurement of 20" (508mm) if you get a measurement of 19.5" (495mm), round up to 20". i dont know how you measure V-belts in Germany but in north america we measure it in inches and in incriments of 1". if your belts are measured in metric then measure it in metric. take your measurements to the auto store and buy a V-belt according to your length.
PS: the sizes i gave you are random numbers i imagined, THEY ARE NOT THE SIZES YOU WANT.
PPS: how fast have you gotten that camaro on the autoban?...dont hold back either
HI USA
Ok i am looking fore a belt.....,thats the better way!
When i drive on the Autobahn....and pusch down.....Topspeed is 140 miles.....,but this car is for germany not fast..,is normal.....a lot of car drives with 250-300 Km/h on the Autobahn.
My little Peugeot205gti is verry fast...about 230 KM/h and that with 155 HP....
what your Toopspeed in USA?
Car: 87 Camaro IROC
probably the same top speed...and im Canadian...not to be affiliated (compared) to USA.
good luck in belt replacement
Gramps
Gramps
I'm not completely sure where you would get it, but the Goodyear part number is 15406, and the Dayco part number is 15400 (I got those #'s from www.partsamerica.com). I think the GM part number is 09433722, according to www.gmpartsdirect.com, but I wouldn't swear to that.
evilstuie
Apr 14, 2016 08:52 PM
rh76camaro
Aug 15, 2015 12:48 PM
mustangman65_79
Aug 11, 2015 03:17 PM
