How to clean heads?
Old Jan 14, 2007 | 02:39 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
How to clean heads?
Im putting a new cam and some valve springs in my car. I decided to do the headgaskets and seals why I am down here. I pulled the heads off today (what a pain in the a**) and here is what they look like. Is there a way I can clean the valves? What should I use to clean them?
Old Jan 14, 2007 | 07:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
How far do you want to go with this? You could take the heads to a machine shop and have them dipped, but that would require total disassembly of the heads.
If you just want to get them clean enough that you won't have any problems with reassembly of the engine, then some brake cleaner and a rotary tool with a soft polishing brush (looks like its made of felt usually) will be what you want. You'll want to clean the mating surfaces on the heads like this (the surfaces for the block and intake manifold are most important) as well as the same surfaces on the engine block and the intake manifold. That will help greatly in getting a good seal with your new gaskets.
Old Jan 14, 2007 | 08:07 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
rotary wheels like 3M work like you wouldn't believe... but if you do not want to use it "gasket remover" in a spray will eat up carbon easily.
Old Jan 14, 2007 | 08:23 PM
ghotachevy's Avatar
soak them in seafoam that stuff works wonders
Old Jan 15, 2007 | 11:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
those are heinous. I highly HIGHLY recommend you disassemble them and get them hottanked. It's only like $40 for that, and they come out looking brand new. They bead blasted mine for me as well, hence the gorgeousness of them.
Oh, and new valve seals while you're there obviously.
Then if you've got the time, bust out a die grinder and go to town.
You could try an oven cleaner or the like, but i've never found any chemical at home that would put a dent in that kind of dirt, compared to a hottanking.
"gasket remover" nelapse you say? Have you used it to dissolve grease and grime like this and it worked? I've gotta try some of that!
Old Jan 15, 2007 | 01:14 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Im in the process of dissasembling them right now. I think I will have them hottanked. I called up my local machine shop and it cost $10 per head What other things should I consider getting done to the heads while they are at the machine shop? This car is my dd but I don't mind taking the time to do things right. Hopefully I remember how to put everything together though My bro and I have been working on it since Saturday.
Old Jan 15, 2007 | 01:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
If you've got some time and cash, (since the hot tanking is freakin' $20!!), get 'em to do the valves at the same time if possible. (hot tank that is)
Check the guide wear. If you've got calipers you can check it, or the machinist can do it for you in about 30 seconds if he's got your valves. You can get thick walled bronze guides put in for.... Well heck, I won't guess the price, you can find out for yourself. Excessive guide wear can cut back 10-15hp.
I'd port the bowls a bit, if you've got a die grinder. This is highly recommended. The bowls can be done fairly quickly, and give the most bang for the buck as far as porting goes. Leave the ports alone, port matching is for wussies
Check the head deck for flatness with a steel straight edge, or, again, let the machinist do it. Decking them might run ya $70 or something, but it'll assure you'll get your new head gaskets to seal right, and bring back your CR if you're going from a thin steel to a composite head gasket.
Old Jan 15, 2007 | 05:48 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Yeah sonix, gasket remover is hardcore. Spray it on some nasty valves or heck anything greasy, it bubbles up and sizzles... you are just watching it cool whatever is on the metal.
Takes paint off instantly too
Old Jan 15, 2007 | 10:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
That settles it, i'm getting a can of that stuff!
Bubbajones_ya
Aug 28, 2015 02:17 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
mdtoren
Aug 23, 2015 12:52 PM
qz6lwp
Aug 20, 2015 08:10 PM
mdtoren
Aug 16, 2015 05:45 PM
