balancer deg. question
Does anyone know the difference in degrees between the newer balancers with the TDC mark near the top and the older style with the TDC mark near the 2 o clock position? I kind of need an exact answer for timing purposes using a dial back timing light.
Transmission: 4L80E/4L80E
The best thing to do is get a piston stop and find TDC exactly with the pointer you've got. You can use the advance timing light and work from there.
The aftermarket damper and tab I got for the 396 were 3 degrees off.
That might be difficult because I have a 2 o clock pointer and a 12 oclockish balancer I was just trying to get it close enough to drive for now , I think I got it about 38 deg. or so
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
"sofakingdom" had rattled off that # before, more of like "and you'll be about this far off, so better get it matched up right", rather than "set your timing light to ____ to get it perfect".
It was around 40* though.
Thats what I did thanks I scribed a new mark at TDC. I was planning on changing the balancer but I may as well just use this one now that it is scribed at exactlt TDC thanks
gixxer92
Sep 1, 2015 04:32 PM
