engine running bad
Old Jan 16, 2007 | 10:27 PM
cobrakiller1989's Avatar
engine running bad
the engine is a 4.3 liter out of a 93 pick-up that my freind swapped into his 2.8 camaro. everything was running fine for months, now he has a code 32 and 33? the car runs very bad and feels like a huge miss. the tune up is brand new. any help?
Old Jan 17, 2007 | 12:53 AM
Gramps's Avatar
Car: 87 Camaro IROC
those are codes for the EGR system, you may need to check the vacuum on the solenoid and the valve. mayb take it to a shop and have them do a lookaround, they can diagnose it and you can fix it, cheaper than replacing parts that may not need to be replaced.
Old Jan 17, 2007 | 07:39 PM
yeah, i noticed the EGR code. being out of the newer vehicle there isnt actually any vacuum lines running to the valve so i guess its just a bad EGR valve. i just didnt know that a bad EGR valve could make it run bad
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
camaroken83
Aug 10, 2015 11:35 AM
