engine light after 70mph???
Old Jan 19, 2007 | 08:17 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
I already replaced my EGR valve and EGR solenoid along with new IAC new o2 sensor and fresh hoses. My 1986 trans am passed beautifully throguh emissions.
i drove it up and down the highway to go get the test done. about a 20min drive one way.no engine light or anything.
a week later i take it down the highway again to a different town to pick up junkyard parts and i noticed my check engine light on doing about 70 and about into my trip. temp and oil was fine
i'm not sure if it means anything. ive taken the car up to at least 40 on back roads no light since that one day. its parked for winter and never got it back up to 70.
just curious for thsoe who really know engines, if theres any kind of mechanical significance or sensor that is supposed to turn on or has a role in the higher speeds that would cause the engin light to show up at high speeds?
it may just be a fluke and mayeb a loose connection but i figured wouldn't hurt to ask
thanks.
Old Jan 19, 2007 | 08:20 PM
Damon's Avatar
Jump the ALDL and get the code out. The ECM stores them for like 50 restarts after it trips the light. Unless it's been started and shut down quite a bit since this happened (or the battery disconnected) there's a good chance the code is still in there.
Old Jan 19, 2007 | 08:22 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok cool thanks I didn't know that. I thought after the light is gone so is the code. but awesome will do
Old Jan 20, 2007 | 12:13 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Well, you said you already replaced it, but the EGR is only active at a higher speed cruising condition....
Old Jan 20, 2007 | 12:33 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yea i thought about the EGR too the car passed emissions no problem with the new EGR and then 3 days later was my trip down the highway that gave me the light
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
