ticking valve
Old Jan 20, 2007 | 09:44 PM
adampousson's Avatar
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
ticking valve
i have a ticking valve.i have hydraulic roller cam.my heads have screw in studs.i tighten the rocker arm ,the ticking goes away for about 3 seconds and it starts ticking again.it comes back gradually getting louder.i tighten it again...same thing.if i had press in studs i would say stud pulling out of head.however this is not the case.im thinking it must be a lifter problem.these lifters have less than 500 miles on them.anyone have any ideas.
Old Jan 27, 2007 | 02:50 AM
rock861261's Avatar
You Have a bad cam
Old Jan 27, 2007 | 10:57 AM
Car: 91 firebird
Transmission: t5
lol.its a brand new cam.less than 500 miles
Old Jan 27, 2007 | 11:40 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if it was flat tappet, i'd say it's a bad cam. I doubt it, since it's a roller.
Only one valve ever does this? I'd inspect the valvetrain very carefully... Loose rocker, retainer, lock, etc ? Something should be visable. A bad lifter could do it, but everytime anyone has mentioned "collapsed lifter" on this board, it's never actually turned out to be the case.
Old Jan 28, 2007 | 06:40 PM
rock861261's Avatar
Still sounds like a bad cam to me have you driven it or let it run it could be just some gunk got into the lifter and not allowing it to pump back up
but i still think its the cam
Old Jan 28, 2007 | 10:48 PM
Car: 91 firebird
Transmission: t5
i swapped lifter...problem solved
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
Stryker412
Sep 7, 2015 09:11 AM
