motor mount
Car: 1991 Camaro RS
Engine: 3.1mpfi swapping in a 2.8mpfi
Axle/Gears: non-posi rear
motor mount
I've got a busted motor mount. If i wanted to secure this engine extremely well, how would i go about doing so. (another factor is having NO cash at all) When i push the throttle, the motor picks up about 1 1/2 feet. (The driver side mount is busted) I'm not going to fabricate motor mounts. I was considering just taking it out, putting an iron spacer in there, drilling a hole(s) through it and the frame, and just running a bolt straight through into the motor. So i suppose my question would be, what would be the most effective way to secure this engine to the frame, with the least amount of cash, plus the simplest form possible with say, chain, cable, or.. any suggestions? Thanks
Car: 1988 Camaro Sport Coupe
Engine: L03 305 TBI
Transmission: Five Speed
Axle/Gears: 3.08
+1 vote for buying new motor mounts.
I just searched and found some stock replacements new for $18, seems worth it to me.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
dude seriously, new engine mounts are dirt cheap
all you need is a floor jack and a socket and a ratchet to replace them, its very straightforward
do it right or dont do it at all
dont be a bozo
if you cant afford something as cheap as chevy engine mounts, or are too lazy to replace them(its the same or more work to try to do the chain or cable thing) then get a bicycle or motorcycle
good luck
r
dont be a bozo
good luck
r
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you wanted to step it up a notch... instead of $12 to $20 for replacement mounts... spend the extra $3 and get poly mounts.
Car: 91 Camaro Vert
Car: 1991 Camaro RS
ok so i spent the last approx 8 hrs in the 20 degree weather with no power in the shed (wires got too hot and melted together causing a short) bolting bolts, jacking car up, tightening crap, mounting chains... and so on, and finally!!!!!!!! the motor is secure via chain! and about 5 bolts, and many adapter plates i had to bolt together also because via the power going out, it made it virtually impossible to use the welder. but anyways it works! and i did it free! and it only took me about 8 hrs!
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Got a question here how do you get past the suspension arm? it is in the way of the nuts holding the engine mount bolts in place. i have got new engine / gearbox mounts and have had a quick look and it looks quite hard to swap them over.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
new SOLID motor mounts.. you have to change them anyway.. moroso makes em.. get em from summit or where ever.. i got solids and absolutely NO loss of torque from a loose motor..
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
