New Engine.
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
New Engine.
I am in the process of gauging engine prices, anyone know a good engine at a good price?
Car: 91 Z28
Axle/Gears: Stock
I suppose that would depend on your definition of "good" in both respects.
I recently bought a new engine to swap from a 305 to 350...in all my searching and research, the cheapest price I found was here:
www.rebuilt-auto-engines.com
If Im not mistaken, the 350 I bought was this one, for about $1200:
http://www.rebuilt-auto-engines.com/...21107283192.35
I cant say how "good" it is, because were just finishing up the swap now...we havent even started it yet.
Good luck!
Good luck!
Engine: V8 305
Well it will probably be $2 or 3000. I am going to get someone else to do it in fear that I would totally screw it up lol... but besides the engine, what else would I need?
Could a corvette engine fit in my car. I think she currently has a 305 TBI, could a SLI be implemented?
This one seems like a good deal. (not corvette):
this is corvette engine:
http://www.rebuilt-auto-engines.com/...38107143000.5e
Last edited by goalieforlife; Jan 24, 2007 at 08:43 AM. Reason: Automerged Doublepost
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
You can get a complete 350 crate motor from gm.It's made for a 1992 fleetwood and runs well I put one in my gta.Call up your local dealership.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
boy, what an immensly broad question, with equally broad answers.
Sure a vette engine will work, I got a '76 "Vette" motor in my garage I could sell ya for $3000, it'd make your car GO like a Vette alright.
GM makes some nice cheap complete motors, for somewhere in the $1800 range I thought. So in Newfoundland dollars you'd be just above $3000 when you're ready to turn the key and run it. 250HP 350CID Goodwrench style engine there.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
the first engine you have there looks like a 82 to 92 corvette & camaro L-98 with the camaro iron 083 heads.The second one looks like the corvette camaro LT-4 WHICH makes great power.They both look like pretty good deals.I`m a little warry of the remans though. I used the fleetwood/caprice TBI goodwrench crate engine that rohmanski was talking about($1,650 new) because the bottom end is the same as the L-98 camaro/corvette engine.the cam and heads are poor and only makes about 200 hp at most so i used the 1996 CORVETTE/CAMARO LT-4 cam (about $100 new) with the 1.6 roller rockers(about $280 new) to get full use of the cam.For the heads i used the ZZ-4 heads which are the same as the alluminum L-98 corvette heads(about $1,100 new) and boom i got a corvette engine.There are good heads that are cheaper,but i wanted to stay as true to third gen original equipment as i could and bolt my tpi right on to it.With the second engine you`ll probably need a different fly wheel if its not a 1 piece rear main seal.Are you gonna go with a carb setup or try to bolt your tbi up to it.There are all kinds of options out there,order a catalog from these guys 1-888-522-8163 pace performance.com they have good prices on new warrentied GM engines and have good help on the phone getting you the power you want at a price you can afford.But haveing someone do it for you is not going to be cheap either.No matter what someone quotes you for a price on an engine swap there ars almost always hidden and unexpected cost that can drive the final price way up.
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Good luck!
Good luck!
Keep me posted because I was thinking about buying that motor for my IROC.
Just wanted to know if someone else had an experience with that motor before I put my hard earning down for it.
Car: 91 Z28
Axle/Gears: Stock
Engine: V8 305
Car: 1987 IROC-Z
Engine: 5.7 TPI
Engine Install
amargari
Nov 10, 2015 02:09 PM
