question about tpi
Old Jan 21, 2007 | 11:33 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
question about tpi
not if this belongs here or on the tpi boards but I have a 67 model 283 sitting around and a tpi off a 86 iroc would it be very hard to convert the 283 from carb to tpi?? just looking for info
Old Jan 21, 2007 | 11:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
not really that hard. just get a wiring harness, sensors and ecm/chip for a 305 and it should run fine.
things you have to look into is the cam...i'm not sure what 283's got and the LSA of those cams. if all possible swap in a L98 cam or LT1cam. will run like a champ
Old Jan 22, 2007 | 01:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The likelihood of a 283, last manufactured in 1967, having a stock cam in it anymore is something along the the lines of the Democrats lowering taxes and winning the war against terror. To boot, the cams mentioned are roller lifter cams, trying to put one of those in an old-school 283 would be an exercise in frustration and expense. However, good, compatible, aftermarket flat-tappet cams are plentiful.
With proper cam and exhaust, assuming the 283 is in decent shape and didn't have small-port & valve heads on it, the TPI would work well on it. TPI is overwhelmed by a healthy 305, so a 283 should be just right as long as the parts are chosen properly for it.
Old Jan 22, 2007 | 03:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
good point, i overlooked that but if you can find the roller lifters from a stocker 305-350 roller motor and swap that in, it will be cheap to do and work great. thats if those rollers will go in...since its not originally a roller block it probly will need retrofit rollers which are expensive. in that sense it would be best to stick with a flat tappet, with fairly mild specs. i just love roller cams, as they make superior power over non roller tappet cams
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
