mini-ram guys, need help
Old Jan 23, 2007 | 10:04 PM
Billy Trammell's Avatar
I used to be a big camaro guy, and back in 2000 I switched teams and got into the mustangs. I KNOW, I KNOW!!!!
anyways, I am sort of back in the same 92 z28 I used to own. I am in the process of a major build-up for it, and since I have been out of the chevy "loop" for 7 years, I am kinda lost. I need some help and info from experienced people.
here's a small break down on the build-up.
stock block... .030 over
stock crank and rods
trw forged pistons
zz9 cam w/new lifters
TF G2 aluminum heads with a very slight port and bowl blend.
TPIS mini-ram
150 shot NOS (compucar wet)
my question"S" are
1) what size injectors should I use for this combo, and will the ford injectors plug right in?
2) what spark plugs should I go with, and set the gap where?
3)will the fuel lines not just "hook-up" to the mini-ram with the supplied hard lines from tpis? If not, what do I need? The lines I have go from the back of the intake(return line and regulator) to the front, right where the throttle body bolts up.
any other info you might want to add, please do!!!!
thanks for the help.
Billy
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
