Highly modded...But only a 2 bolt main.
Old Jan 23, 2007 | 08:36 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Title sums it up. Am I going to need to worry about messing up my engine? If so, What can I do? I can't do much motor work being 16. My mods are in my sig.
Old Jan 23, 2007 | 08:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Having 2 bolt mains won't make a difference in any way that you need to care about on a streetable engine.
Old Jan 23, 2007 | 09:04 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
2 bolts are good up to 400-500 hp and a good 7000 rpm before they give up. Probably not if you always hammer it but occastionally you should be fine.
2-bolt blocks with OEM main bolts are good to 400hp
2-bolt blocks with ARP main studs are good to 550hp ++High Nickel Blocks to 700hp
4-bolt blocks with OEM main bolts are good to 475hp
4-bolt blocks with ARP main studs are good to 700hp
OEM Blocks with Splayed 4-bolt main studs are good to over 950hp
Bowtie blocks with splayed 4-bolts main studs should handle over 1500+hp!
at this website: http://www.montecarloss.com/SSThunder/SBCinfo.html
Old Jan 23, 2007 | 09:07 PM
blazed's Avatar
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Transmission: 700r4, shift kit
Its gonna take a heller powerfull street engine to make a two bolt main give out. I have seen 650HP street engines running a two bolt main
Old Jan 23, 2007 | 09:12 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
also found this on there:
Engine RPM plays even a larger factor in determining safe power limits for various block/cap combos.
OEM 2-bolt blocks are good to 6000 rpm.
2-bolts with ARP studs are good to 7000 rpm.
OEM 4-bolt blocks are good to 7200 rpm.
4-bolts with ARP studs are good up to 8500 rpm.
Bowtie or OEM 4-bolt Splayed Studs and cap are good for well over 8500 rpm
Old Jan 23, 2007 | 10:25 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay,
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
