fuel injectors
Old Jan 28, 2007 | 08:29 PM
toms86Z28's Avatar
fuel injectors
im putting in a 350 in place of my 305. i wanted to know if i put in 24lb. injectors will the motor run right. and would i have to have the prom programmed for the injectors? and how much hp. can the 24lb.s handle i also got a holly afpr. or what about 26lb.
Old Jan 28, 2007 | 08:38 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I always recommend that the chip reflects the injector size used, will the engine run correctly if you don't? More than likely. I believe there is a sticky somewhere for injector/HP. Usually the stock injectors are quite capable of supporting decent HP until you start upgrading H/C/I.
Old Jan 28, 2007 | 08:55 PM
toms86Z28's Avatar
im trying to find out because i dont want to have to go out and buy new injectors after i just bought a set. as of right now the motor is stock and come this summer the cam, and heads. slp runner ported plenum and im getting a ported gm base. in a week. what if i just go with the 24lbs. and at the end of the week im getting a tpis prom from some one. its already set for.calibrated for headers, cooler thermostat, and better intake airflow, as in no air filters, no MAF screens, and a larger throttle body
Old Jan 28, 2007 | 09:14 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Modification + prom = power
It is essential when modifing a computorized car that You decide exactly what kind of power you are wanting to make. Everything must work in harmony. As an example if you are getting more fuel and air into the engine but left the stock exhaust in place you are not getting all the power from the previous upgrades because of your restricted exhaust. Bigger injectors + adjustable fuel pressure regulator + better spark MSD 6AL + bigger throttle body + bigger exhaust + prom made for those specific upgrades = lots more power. Take anything out of the equation and you are losing power, and possible for car to run like crap.
Old Jan 28, 2007 | 09:56 PM
toms86Z28's Avatar
ok i got the full exhaust, descreen maf. ported lower intake, im ordering a 52mm tb. i have a fully worked 700. adjustable fuel pressure regulator. msd 6al box. and im getting a tpis and im gunna send it out to tpis to have it redone.
Old Jan 29, 2007 | 04:26 PM
toms86Z28's Avatar
i was just reading about a set of 24lb. injectors. and they said there stock replacment. and don't need to do anything to your computer
Old Jan 30, 2007 | 01:15 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Third gens did not come with stock 24lbs injectors. Either 19lbs or 21lbs. If you change them out without modifying the PROM then you will be running the risk of WAY too rich and we will see you posting back shortly afterwards...
Old Jan 30, 2007 | 04:40 PM
toms86Z28's Avatar
these are what i was looking at. my friend has them in his but i dont know what else was done. he just bought his car.read under where it says application
http://http://store.summitracing.com...5&autoview=sku
Old Jan 31, 2007 | 03:42 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
24lb (are LT1,) inplace of 22, or 21lb injectors is an increase of 10 to 14% respectively.
IMO a 10% increase is on the high side of what the ECM can adjust the injector pulse width to compensate for the higher flow if the extra fuel isn't needed, which would be more of a problem at idle.
Reducing the fuel pressure can compensate for the extra fuel if it isn't needed, but also reduces fuel atomization efficiency.
Old Jan 31, 2007 | 10:32 AM
toms86Z28's Avatar
i wanted to go a little bigger because this summer im doing a cam. heads. and getting the slp runners to go with my ported base and plenum
Old Jan 31, 2007 | 08:19 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Go for it.
Old Feb 1, 2007 | 08:39 AM
toms86Z28's Avatar
so i shouldn't really have any problems then with the 24lbs. what pressure should i put the regulator at so it will run rite?
Old Feb 1, 2007 | 09:16 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Set the pressure with the engine off.
3 bar = 43.5 psi
Old Feb 2, 2007 | 08:54 AM
toms86Z28's Avatar
and it will run fine? a/f should be around stoich
Old Feb 3, 2007 | 08:30 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
As long as the O2 is working properly.
Take it for medium cruise, and vary the mph from time to time so it can adjust itself.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
