Pushrods: chromemoly vs. steel
Old Jan 29, 2007 | 01:17 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
What's the difference? Why is chromemoly so much more expensive than hardened steel? Would it actually be worth it to spend so much more on chromemoly?
Old Jan 29, 2007 | 02:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
They're stronger and lighter. For valvetrain that's a good thing.
Is it worth it? That's up to you. If you're not over 6000RPM much, I wouldn't sweat it.
I'd do regular ones, the cheesy $30 guys.
Old Jan 29, 2007 | 08:38 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Sonix
...I'd do regular ones, the cheesy $30 guys.
I'll go ya one better. I run the stock ones past 6500. Chrome moly: Good for use with strong valve springs and high lift cams. They flex less too.
It depends on the application whether they are a necessity or a waste of money.
Old Jan 29, 2007 | 10:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, I'm still using a mix of 305 LG4 and 350 pushrods. They weren't bent so....
But I figured if you had your heart set on buying new ones...
Old Jan 30, 2007 | 06:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Hmm.
I'll be running high lift but won't be spending much time over 5800. I guess the hardened steel will work for me.
Thanks for the info. I searched a long time and did not find this answer. Now it should be easy for anyone to find.
Old Jan 30, 2007 | 06:50 AM
Chrome-moly is stronger than most other alloys, so you can get the same strength with thinner material, which ends up being lighter.
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
skinny z
Oct 5, 2015 06:23 PM
roysatikas
Sep 22, 2015 08:15 PM
