oil galley plug in lifter valley
Old Jan 29, 2007 | 09:15 PM
adampousson's Avatar
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
i took off my intake manifold to change out a bad lifter and too my suprise there was an oil galley plug just laying in there.kinda chewed up.im thinking its one of the plugs right above the camshaft right?well what kind of problems is this going to cause me if i dont take the timing cover off and put it back it.my oil pressure is still very strong.60 psi at cruising speeds.
Old Jan 29, 2007 | 10:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yikes! I'd be worried how it got THERE...? It'd give a big oil leak, loss of oil pressure to half of your lifters and cam.... Pretty bad thing i'd say.
May very well explain a "bad" lifter eh? Or, the bad cam you're about to find. Sorry.
Old Jan 29, 2007 | 10:38 PM
Car: 91 firebird
Transmission: t5
i still have oil squirting out of all of my rocker arms
Old Jan 30, 2007 | 06:28 AM
If the motor isn't acting wrong in any way, I wouldn't worry about it. It might have come from someplace completely else, like somebody accidentally dropped it down the distributor hole while working on the car, or some such. (not that stuff like that ever happens, right???...) There's basically no way it could have fallen out of the front of the block, and ended up sitting in that particular place.
Old Jan 30, 2007 | 08:47 AM
Vader's Avatar
How big is it? If you check the diameter, you might be able to determine if it was infact a gallery plug, or something else, like a tamper plug from a thottle stop screw, etc. There's no way you're missing an end plug and still making 60# with hot oil.
A gallery plug could have ended up in the valley if the car was previously owned by Joey Chitwood.
Old Jan 30, 2007 | 08:10 PM
Car: 91 firebird
Transmission: t5
who is joey chitwood?
fully warm im getting 65# cruising and idling im getting 35#.i dont think my gauge is off.i geuss its possible.the diameter is 1/2".
db057
Sep 4, 2015 07:57 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
