Question about my 91 RS.
Old Jan 30, 2007 | 01:33 PM
blaZerTire's Avatar
When I pull the dipstick there is gunky build-up on it. It's color is like an off white. It's not mixing with the oil changing the oils color, it's separate, and when I changed my oil it wasn't in the oil. Could this be a vaccuum leak or something allowing water to build up or something? I was also told the motor was rebuilt, is there a chance it could be rust inside the engine? or if it was rust would i obviously see it in my engine oil when I change it? I'm not losing any coolant really either, so I don't believe coolant is mixing in my oil to cause that. I do notice that if my dipstick isn't properly seated on the tube when I run my engine some oil will come out the top of it and get on the headers and burn off causing smoke.
Old Jan 30, 2007 | 04:11 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
oil should not just come out of the dipstick unless there is something wrong with your pcv valve but who knows...when you say gunk is it paste is it slime is it crunchy?
Old Jan 30, 2007 | 05:44 PM
Off-white gunk = water
How's your PCV system? Drawing plenty of vacuum through the valve; Got the tube going into the other valve cover hooked up to a source of FILTERED air?
If all of that is good, then you have a coolant leak; you just haven't noticed it yet.
Old Jan 30, 2007 | 10:09 PM
blaZerTire's Avatar
I'll check my PCV valve and see if it's still good. The off-white stuff isn't crunchy, but it's thicker than oil by far. I'll take a picture of it sometime soon and post it on here so you all can see it.
Thanks for the replies.
Old Jan 31, 2007 | 06:17 AM
I don't think a pic is necessary. We've seen it before.
It's water. Mixed with oil. It looks about like mayonnaise.
Old Jan 31, 2007 | 05:36 PM
blaZerTire's Avatar
ahh yes like mayonnaise! I now notice my dipstick tube is wiggly, is it tightenable or replaceable without having to drop the oil pan? Or is a little give normal? I was thinking since I didn't see any "mayonnaise" in my oil when I changed it that perhaps moisture is building up at the base of the tube. I'm not sure.
Frozer!!!
Jan 19, 2024 04:55 PM
Genopsyde
Oct 7, 2015 08:35 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
