stock l98 heads
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
stock l98 heads
before anybody tells me to search, I have searched for 3 days and also been through google...
should be a simple question, did not know this would turn into some type of quest....
spec's for the stock cast L98 heads, this is in a 88 bird 350 TPI.
(not aluminum)
looking for cc's and such
thanks
(not aluminum)
thanks
Transmission: 4L80E/4L80E
Valves: 1.94" intake, 1.50" exhaust
Chambers: 64cc-ish
Intake ports: 170cc-ish
Rocker studs: press-in (aka - "pull-out")
Valve springs: weak, heavy rotators on exhaust valves
Rockers: self-aligning
Chambers: 64cc-ish
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Stock heads max lift = .460 range, I actually believe I heard that from him a few days ago.
theshackle
Mar 5, 2017 06:37 PM
