small scratch on crank journal
Old Feb 1, 2007 | 11:30 AM
Bo1226's Avatar
Car: 83 Z28 modified 350
Ok I had to put a new crank kit in my 350 due to bent crankshaft. This was a completely new build and was caught before any damage. So I had alot of problems installing the new crank w/top end all still together but I finally got it. Problem is I noticed I scratched the crank journal where #4 connecting rod goes. My question is HOW BAD IS THIS? And what are my options other than taking crank back out and having machine shop grind it down? I guess this is how you get experience huh?
Old Feb 1, 2007 | 11:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's a really light scratch you might be able to just polish it out.
A couple of pieces of 3/8" hose on the rod bolts will keep that from happening again.
Old Feb 1, 2007 | 01:59 PM
Bo1226's Avatar
Ya I know, I had little rubber pieces on all the pistons, but one fell off and didn't know it until too late. I'm not sure how to tell if its really light or deep. I can feel it and its probably about 1/4" long. How would I polish it. And what will happen if its too deep and I run it?
Old Feb 1, 2007 | 03:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you can feel it then it's probably too deep to be polished out. Running it like that will destroy the bearing in fairly short order.
morrow
Jan 13, 2024 12:29 PM
Jake_92RS
Jan 28, 2020 10:37 PM
anesthes
Mar 10, 2016 10:35 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
