install the distributor.
Old Feb 2, 2007 | 02:24 PM
devilfish's Avatar
Got a new distributor from summit, Is it "normal" that you need some force to install it? I lined up the oilpump etc and the distributor falls in to place, but to get it fully down, ( the last 3mm ) i need to twist it left and right aswell as apply some pressure. Now it seals perfect against the intake. And I have tried to rotate the engine by hand, and no strange sound or anything seems to grind. I never done this before, and I just follow info from the net aswell as my service manual. I even reinstall the unit twice to be sure. And every time it needed the extra "push" to seal against the intake.
Car is a -91 corvette with a converted lt1 intake. So i use the small cap camaro distributor.
Old Feb 2, 2007 | 03:05 PM
Sometimes they're like that; they fit kind of tight to the hole in the block that's right above the distributor gear.
If it went in all the way to the intake though, it's fine.
Old Feb 2, 2007 | 03:09 PM
devilfish's Avatar
thanks m8. I guess im fine
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
gixxer92
Sep 1, 2015 04:32 PM
355sbcTPI
Aug 19, 2015 04:38 PM
stalkier
Aug 7, 2015 04:49 AM
